It is currently Thu Aug 21, 2025 5:37 pm
Post new topic Reply to topic  [ 36 posts ]  Go to page Previous  1, 2
PostPosted: Sun Aug 04, 2013 5:34 pm
First name: Miguel
Last Name: Bernardo
Country: portugal
Hand plane is good enough for me.
PostPosted: Mon Aug 05, 2013 5:07 am
Last Name: Eaton
City: Lamoine
State: ME
Zip/Postal Code: 04605
Alan Carruth wrote:
If you pull a rectangular brace into a holder with spacers at the ends, and trim it flat, what you get is not a circular arc. It's close, and many consider it 'close enough', but technically....
Is that really the ultimate goal? Are we aiming for and exact radius of a perfect circle. I agree with Jim in that this method creates a really nice fair curve, which IMO is the ultimate goal. I'm personally not aiming to hit an exact arc of a circle and would rather have something a little more fair than perfectly round. Just think this is a nicer feel and a bit more organic than perfect circles. But this has a lot to do with people's method of building as well. And I'm not sure one way is better than the other, just a personal opinion.
PostPosted: Mon Aug 05, 2013 9:11 am
Does anyone believe it needs to be a circular arc?
James
PostPosted: Mon Aug 05, 2013 9:17 am
I just use a block plane and plane to a pencil line. It's not complicated. There is no best way really but I think the OP might be asking about another problem here. The radius sanding dish should work just fine. If I understand the OP he is saying that he sands out the radius and then has a left or right tilt on the mating surface so that if the brace is glued it will not be at a right angle to the soundboard or back. The best thing to do when sanding anything on a sanding board is to take a few strokes then flip the work piece around and sand a few more and repeat. This eliminates any systematic error when sanding in one direction over time.
PostPosted: Mon Aug 05, 2013 12:14 pm
First name: Rodger
Last Name: Knox
City: Baltimore
Zip/Postal Code: 21234
James
Yeah, there's probably someone who believes it. There's lots of people who believe things that aren't true. beehive
PostPosted: Mon Aug 05, 2013 12:28 pm
Last Name: Fifield
City: San Jose
Zip/Postal Code: 95124
Tony_in_NYC wrote:
Laser beams.
Sent from my iPhone using Tapatalk 2
+1 :D
Dave F.
Cambrian Guitars
PostPosted: Mon Aug 05, 2013 5:23 pm
Last Name: smith
City: hemet
State: ca
Zip/Postal Code: 92543
It seems to me that braces cut to a radius as demonstrated aboce will not fit exactly a radius board if one is used for glue up. The only way to get a brace to fit a radius board is to sand the brace on the board.
Also it seems to me that wherever a brace is sanded it will be the same. It doesnt need to be sanded in position.
Please correct me if I am wrong.
PostPosted: Mon Aug 05, 2013 6:59 pm
First name: Trevor
Last Name: Gore
City: Sydney
What you need is a brace that fits the panel with no gaps and gives you your design curvature. One of the main reasons that circles/spheres are used is that any brace will fit perfectly on any panel of that curvature in any position/angle, without having to apply a heap of force. That is not true of, say, parabolic or spline curves. And that single feature can be a major time saver. It's pretty difficult to see on a finished guitar the difference between spherical, parabolic or spline and more difficult (I would contend) to hear it.
http://www.goreguitars.com.au
PostPosted: Thu Aug 08, 2013 6:22 pm
Last Name: Beaver
City: Lake Forest
I use one from Tracy at Luthier Suppliers, a sponsor here. It is basically the same as the one David Ingalls showed. You can pick two radius when you order it.
Works great!!!
Joe Beaver
Maker of Sawdust
PostPosted: Thu Aug 08, 2013 6:41 pm
First name: Tony
Last Name: C
City: Brooklyn
Dave Fifield wrote:
Tony_in_NYC wrote:
Laser beams.
+1 :D
Dave F.
I was waiting for you to show up! I had to represent in your absence.
http://www.CostaGuitars.com
PMoMC
PostPosted: Thu Aug 08, 2013 6:52 pm
First name: Rob
Last Name: McDougall
City: Cochrane
State: Alberta
One point not mentioned as yet is some folks preference to glue with planed vs sanded surfaces.
Sanding to radius on the dish then a pass with a plane would suffice.
I plane mine to a pencil marked radius per Mario's video - fast and simple on a shooting board.
Rob
Users browsing this forum: TripodBob and 15 guests
